May I know how to find the CG (Center of Gravity) of a component in SL?
Go to Inspect > Mass Properties to find the CG of a component.
Thank you Santhos very much for your help. I tried and it worked pretty well.
I also found that they can be copied(Ctrl+C) and I can paste on Excel.
