I am run some acoustic analysis (infinite element). May I know if Simlab has any functions to create mesh for this kind of analysis?
Go to Mesh > 3D Create > Acoustic mesh. This will create mesh for acoustic analysis.
Hi Santhos,
Thanks for your comments. It sounds great feature.
However, I am unable to generate Solid (tetra or Hex+Penta) as your picture.
May I know what is input for this function?
+ Input should be Watertight surface mesh? or some gaps is OK?
+ Input must be no intersection?
It accepts only single model only right?
