I see the option to import HM database in Simlab 2019.3 but I cannot import HM 2019 data.
I test with HM 2017 is OK?
May I know SL 2019.3 does not support HM 2019 or any issues on my setting?
Hi.,
SimLab 2019.3 can import the HM file saved in the version lesser that 2019 and it wont import HM file saved in HM 2019.
But in SImLab 2020 beta, we have supported to import HM file saved in HM 2019.
Thanks & Regards
KamalRaj
Senior Application Engineer – SimLab
Altair | Nasdaq: ALTR
kamalraj.rajagopal@altair.com | altair.comConnect with us: LinkedIn | Twitter | Facebook
Hi Kamal and Alessio
Thanks for your detail information.
I found another issue with import Radioss solver file, some mesh is distorsion. Optistruct is OK.
Do you know if we have any limitation on import Radioss solver file (Mesh only, not material)?
SimLab have support to import mesh along with below listed material types.,
But mesh should not get distorted while importing. If possible please share your Radioss solver file.
