can i simulate milling process in Radiosis. if yes give some refererances for that
simulating maching process can be done in Radioss, but there are some issues:
-due to timestep considerations, these simulations are computationally intensive
-proper definition of failure (damage)models is essential
There are no milling examples in Radioss yet, but the screwing process is analogus:
https://altairuniversity.com/learning-library/radioss-sample-of-a-screwing-process/
Try to implement this approach in Radioss:
You can also model your part using SPH with solid properties and your tool as a rigid surface.
thank you Mr.simon and Mr.Adriano
Here an example model created by a colleague, /profile/47305-rodrigo-merigo/?do=hovercard' data-mentionid='47305' href='<___base_url___>/profile/47305-rodrigo-merigo/' rel=''>@Rodrigo Merigo
