Dear HyperMesh User,
I have question concerning body visibility. How to set the visibility of the solid body in HyperMesh in the same way like in SimLab? HyperMesh shows the body as SOLID (filter) but it bahaves as outer surface only(no solid cross-section, cross-section is transparent, the inner parts edges can be seen). Compare to SimLab there is the body with filled cross-section.
I tried to export as h3d format and open it in HyperView it does not work either.
Thank you for reply.
