Hello Everybody, Dear Altair Users,
how to export contact force, force in contact type FREEZE or TIE in frequency response, random response for each contact and to see the resultant force in HyperView of each contact?
Thank you.
Hi Zdenek,
If you are trying to view contact force in hyperview, then you can define CONTF output which will give you the contact result to be viewed in hyperview.
With Format=OPTI, it will write .cntf file which is an ASCII file containing information on total contact force, normal contact force, tangential contact force, and contact area.
To know more on this you can refer the below link.
CONTF (altair.com)
Thanks
Rajashri
