Hello everybody,
I have component done by hexa element, no solid part association, the elements only. I used the command Validate - Face to make outer shell element of hexa element component. What is the best way to separate these shell elements from soild HEXA element? The solid elements appears when I isolate shell elements (made by Validate - Face) and click on show adjust - J shortcut. I want to seperate and make independent shell mesh from solid mesh.
Thank you.
