I am analysing the effects of a magnetic core in a winding at high frequency. To do so, first I'm comparing 2-D and 3-D simulations, as the 3-D simulation should calculate more precisely the Eddy currents in this magnetic core, comparing the impedance of the conductor.
As I read in the literature, using complex permeability for the material in 2-D will give the same impedance results that in 3-D, but when I simulate the three options, the 3-D gets a lower impedance than the other two.
I Flux doesn't let me solve the problem unless I put an electric loop cut in the iron sheet, can this be the cause of the miscalculation?
I attach the 3-D simulation.
Thank you
Yerai
