Hi
I have a question. I am making a linear structural analysis for some parts and the results of forces on bolts are strange. Only 1 bolt out of 16, has significantly bigger force. It's weir, cause all bolts are same size, material nad theoretically they should have the same load as they are at same height of a cylindrical surface. All bolts are tightened.
You can see it on a photo which is attached.
What can be a problem, and how to solve it?
Maksymilian Chełkowski-Klasa
