I would like to know if there is a certain way to design the magnets with an Halbach-Array. If it is not possible in fluxmotor, is it possible in Flux ?
Hello Alvaro;
In FluxMotor, it is possible to use this part for halbach. If it is not the one you want to do, you still have possibility to use the spacial magnetisation.
Best regards
Hello Alvaro; In FluxMotor, it is possible to use this part for halbach. If it is not the one you want to do, you still have possibility to use the spacial magnetisation. Best regards
Hello Farid, first of all, thank you very much for the fast response.
The design I have in mind is using V-block (V-shaped) magnets in Halbach-array. It is basically a design very similar to the Tesla model 3, an IPMSynRM.
I want to design the magnets in V shape using segmented magnets in Halbach array.
If there is a way to do that in flux motor, please let me know how I could do it.
Thank you very much
