Hi all,
I am trying to get the "Linear actuator" example running for transient magnetic 3D application.
I added the steps from "Translating Motion Tutorial - 3D Technical Example" - Case 2: Study using the coupled load kinematic model (with circuit coupling).
I ran into following issues I don't know how to resolve:
When I don't assign the "mechanical set holding the coil" I get following error:
The mechanical set FIXED_PART is not used
No mechanical set for COIL_1
Coils without mechanical set on stranded coil COILCONDUCTOR_1
The project has non meshed coil but it has no region
with reduced potential formulation :
MT3RED or MT3SCRHJ (or MT3SCRT0W)
Unable to solve the project
When I assign "FIXED_PART" to "mechanical set holding the coil" I only get a warning, the solver starts but fails:
Begin of physical check ...
End of physical check.
Active formulation(s) :
MT3SCRHJ : Transient magnetic HJ reduced scalar potential formulation with ci
MT3SCA : Transient magnetic total scalar potential formulation
Matrix system : non linear, real, symmetrical
Problem while evaluating. Unable to solve the project.
Incorrect dimension for mechanical set: 1
I hope someone can help.
Tom
