Hello, I created a compression simulation model (a cylinder between a fixed plate and a flexible plate), it has warnings(initial penetration in interface) when calculating and the calculation time increases continuously. I've read some posts and I used the check tool to fix the intersections automatically. Also, I chose interface TYPE19 between contact surfaces of plate and cylinder, I set Igap=1,Inacti=6.
I doubt maybe the mesh is not good or there are some problems in contact interface settings(there is no physical gap between plates and cylinder when modelling).
The attached files are solver decks. Could someone help me to find out the problems?
