Failing to import Inventor Files - "Error managing neutral data from client side"
User: "EB_21846"
Altair Community Member
Updated by EB_21846
My organization is currently rolling out HyperMesh and have hit a roadblock - we are failing to import a .ipt or .iam file from Inventor.
According to the documentation, both .ipt and .iam are supported file types.
Here is my troubleshooting so far:
I am importing with default settings, and the only thing that appears in HyperMesh is a Title, without geometry.
Note that converting to a step file and importing that will properly load the file.  This is our current workaround, but it's an extra step I'd like to circumvent.
Upon researching CAD importing issues, I found that there are log files for imports.  Some samples from "ct_reader.msg" for failed imports have been attached to the end of this post (names have been removed from file paths, these come from separate users).
There is a persistent error message of "Error managing neutral data from client side" - does anyone know what causes this and how to fix it?  We are new to this software, so my hope is that it's a basic error.
 Thank you!
****************************************************************************  Info        : INVENTOR Reader  Info        : HyperWorks Version 2023.1.0.21  Info        : Input file - C:/Users/XXXX/OneDrive/Projects/CAE/2P 10 in BR/A1020945.iam  Info        : Translator used - C:/Program Files/Altair/2023.1/hwdesktop/io/cn_translators/bin/win64/ct_reader.exe  Info        : Translation start time - 02-28-2024 14:53:52  Info        :   Info        :   Info        : --------------------------------------------------  Info        : Import options selected in HyperMesh  Info        : --------------------------------------------------  Info        :   Info        :   Command line options  Info        :   ----------------------  Info        :   AttributesAsMetadata              = off  Info        :   AvoidPartAttributes               = off  Info        :   BodyIDAsMetadata                  = off  Info        :   CleanupTol                        = -0.01  Info        :   ColorsAsMetadata                  = off  Info        :   CreationType                      = Parts  Info        :   DegSurfTol                        = 0.0  Info        :   DensityAsMetadata                 = on  Info        :   DisplayRepresentation             = off  Info        :   DoNotMergeEdges                   = off  Info        :   ImportBlanked                     = off  Info        :   ImportCoordinateSystems           = on  Info        :   ImportFreeCurves                  = on  Info        :   ImportFreePoints                  = on  Info        :   LegacyHierarchyAsMetadata         = off  Info        :   MID                               = MaterialId  Info        :   MaterialName                      = Material  Info        :   MeshFlag                          = MeshFlag  Info        :   OriginalIdAsMetadata              = on  Info        :   PID                               = PID  Info        :   PartNumber                        = PartNumber  Info        :   Revision                          = Revision  Info        :   ScaleFactor                       = 1.0  Info        :   SkipCreationOfSolid               = off  Info        :   SplitComponents                   = Part  Info        :   StitchingAcrossBodies             = on  Info        :   TargetUnits                       = IPS Std (in pounds lbf s)  Info        :   ThicknessName                     = Thickness  Info        :   UID                               = UID  Info        :   VariantCondition                  = VariantCondition  Info        :   VariantScope                      = VariantScope  Info        :   Info        :   INI file options  Info        :   ----------------------  Info        :   AvoidThirdPartyConversion         = on  Info        : --------------------------------------------------  Info        :   Error       : Error managing neutral data from client side  Info        :   Info        : Translation end time - 02-28-2024 14:53:52  Info        : Translation duration - 0.000000 sec  ****************************************************************************
****************************************************************************  Info        : INVENTOR Reader  Info        : HyperWorks Version 2023.1.0.21  Info        : Input file - C:/Workspace/XXXX/Working/Vice Fixture.ipt  Info        : Translator used - C:/Program Files/Altair/2023.1/hwdesktop/io/cn_translators/bin/win64/ct_reader.exe  Info        : Translation start time - 02-28-2024 12:29:58  Info        :   Info        :   Info        : --------------------------------------------------  Info        : Import options selected in HyperMesh  Info        : --------------------------------------------------  Info        :   Info        :   Command line options  Info        :   ----------------------  Info        :   AttributesAsMetadata              = off  Info        :   AvoidPartAttributes               = off  Info        :   BodyIDAsMetadata                  = off  Info        :   CleanupTol                        = -0.01  Info        :   ColorsAsMetadata                  = off  Info        :   CreationType                      = Parts  Info        :   DegSurfTol                        = 0.0  Info        :   DensityAsMetadata                 = on  Info        :   DisplayRepresentation             = on  Info        :   DoNotMergeEdges                   = off  Info        :   ImportBlanked                     = off  Info        :   ImportCoordinateSystems           = on  Info        :   ImportFreeCurves                  = on  Info        :   ImportFreePoints                  = on  Info        :   LegacyHierarchyAsMetadata         = off  Info        :   MID                               = MaterialId  Info        :   MaterialName                      = Material  Info        :   MeshFlag                          = MeshFlag  Info        :   OriginalIdAsMetadata              = on  Info        :   PID                               = PID  Info        :   PartNumber                        = PartNumber  Info        :   Revision                          = Revision  Info        :   ScaleFactor                       = 1.0  Info        :   SkipCreationOfSolid               = off  Info        :   SplitComponents                   = Body  Info        :   StitchingAcrossBodies             = on  Info        :   TargetUnits                       = CAD units  Info        :   ThicknessName                     = Thickness  Info        :   UID                               = UID  Info        :   VariantCondition                  = VariantCondition  Info        :   VariantScope                      = VariantScope  Info        :   Info        :   INI file options  Info        :   ----------------------  Info        :   AvoidThirdPartyConversion         = on  Info        : --------------------------------------------------  Info        :   Error       : Error managing neutral data from client side  Info        :   Info        : Translation end time - 02-28-2024 12:29:59  Info        : Translation duration - 1.000000 sec  ****************************************************************************
1 - 1 of 11
