Good morning:
I've recently started working with Hyperlife and I've got some questions regarding Load Map section:
1. What is LDM and what is its relationship with the load of the subcase?
2. The subcase's loads that don't vary cyclicaly need to always be taken into account for fatigue or only when their contribution to the mean stress wants to be considered? How would you represent them in the Load History with Hyperlife?
3. If in a subcase instead of a punctual load I have a pressure or moment applied and I want to create a fatigue event from that, do I need to change the values of the magnitude from N/mm^2 or N*mm to N for both the load history and LDM? I say this because the plots for the load history are in Newtons vs time and I haven't found a way to change the units.
Thank you for your time
