I have modeled a 3x3 cube in hypermesh that is going to be subjected to steady state heat transfer. I want to collect the heat flux magnitudes in the y-direction at two different 'planes' on the center cube. I cannot select the entire face because I need to only see the face of the 'center' cube and not the 'outside' cubes. How do I collect these specific points? I have attached a PDF of what I'm trying to do. This is a carbon fiber 'unit cell'. The circles are carbon fibers, everything else is resin. I've placed a solid box over the boundaries that I want to collect the heat flux magnitudes at to help better illustrate what I'm trying to do.
Also, what is the difference between the Element, Analysis, and global drop down box under the contour tab?
