I am new doing heat transfer analysis with OptiStruct, and I need to solve the following problem:
2 coaxial cylinders (see image below)
The inner Surface of the external cylinder (blue) is generating a heat flux, which makes to increase the internal cylinder temperature (by convection).
I need to know the temperature of the small cylinder (yellow) and I don´t know how to proceed to solve this kind of problems.
What are the guidelines to solve this problem?
Thanks in advance!
