Hello all,
i need some help from your side. I'm trying to export my fluxmotor model to flux2d, but when i export it i dont get the same torque.
Any advice from your side? I've uploaded my fluxmotor model here:
https://www.sendspace.com/file/omqywr
Regards
Hello Noti;
FluxMotor is based on a mix between Finite elements method and Analytical method. The analytical method is used to compute the circuit, and Park model is used to compute the performances.
The Park model need to respect some points, the first one is that only sine shape supply is used, and the second one is that the motor is supposed to be not very saturated.
So it is normal to see a smal difference from what computed in FluxMotor and what you have in Flux.
Can you attach your FluxMotor project directly here an not to use a link, if it is a big file, i will send you a link to upload your file.
I attached my model here. Thanks for any advice.
Hi;
Can you please send us your FluxMotor project instead of the connector component to HyperStudy ?
Hi; Can you please send us your FluxMotor project instead of the connector component to HyperStudy ? Regards
i dont understand it, maybe because im not that experienced in flux/fluxmotor. I moved that folder (which i exported from Hyperstudy)to the fluxmotor catalog and opened it from there.
any advice from your side?
Best regards
Please send me your FluxMotor project, the one you sent is not the right one.
Do you know how to send it ?
i dont get your point, i exported that project from Hyperstudy and i open it on fluxmotor. For me it works right if i move the folder to the FluxMotor\FluxMotor2019.1\UserCatalog\User_SM_PM_IR_3Ph\Motors
But as i mentioned im novice, so maybe im doing it wrong. So can you please guide me and tell me what should i do?
Thank you in advance and best regards
Hi ;
Please follow the process described in the following pdf.
thank you for your guide. I did the same the other time but anyway, please let me know if it works for you now. Thank you!
Best Regards
Hello;
Thank you for the file, now I managed to recover your FluxMotor project.
I made two tests one with 1100 A as you did, here the results from FluxMotor are far from the Flux 2D one.
The second test is with 110 A, here I hade 1680 Nm from Flux and 1704 Nm from FluxMotor.
The first test lead to a very saturated machine, and in this cas, FluxMotor is not adapted to make this study. As I answered previously, FluxMotor is using Park Model, so the studied machine should not be saturated, otherwise we will have lot of harmonics that the model do not take into account.
Please note, that in the test I PSI N, you have access to the flux density color shad, so you can see that a big part of the machine is close to 2T or more, that can give you a first answer on the accuracy of FluxMotor results when the machine is saturated.
I hope this will help you.
