I need to figure out how to import on Wallman some files and then merge them together.
The type of files i have are .grd , .tab and .txt .
i have all those files 2 times,as a ground description and as a buildings description.The maps are in Mapinfo and WGS84 form.
My issue is, how can i import both of them into wallman and after i do that ,how can i convert them to one so i can use it on ProMan.
Thanks in advance
