Currently, i am trying to learn, how to use Sequence of loads. But I have a problem.
I have a bolt that I want to preload in steps.
For example, add 500N for the first step, 1000N for the second step, and so on.
Another situation is that there are multiple bolts, the No. 1 bolt is preloaded first, then No. 2 and No. 3. Each step needs to extract the preload of other bolts.
Thank you so much for your help
