If I delete the lines in the "run history" window to release memory, what is in fact deleted?
Can I collect the older results if I delete the history by error?
If you delete something from run history, Your older run will be deleted and can not be collected. Run history shows the location where your all the simulation data is being stored unless you have changed the location.
