Self contact in optistruct
hi people,
at present, i am practing about self contac in optistruct, but the result of simulation is not righ, that is why please help me, thank
condition: hyper 2017
*both Part A and part B use material Fe, E 70 Gpa.
* i carry out many situation to self contact, but is not ok
-situtaion 1
Patten1
Card image: contact
Type:slide
Ssid : part a and part B
Msid: part a and part B
Morient: norm
Discret:S2S
Trach:Consli
-situtaion 2
Patten2
Card image: contact
Type:slide
Morient: norm
Discret:S2S
Trach:Finite
Patten3
Card image: contact
Type:slide
Morient: norm
Discret:S2S
Trach:small
refence document
https://community.altair.com/community?id=community_question&sys_id=1966ccf61b2bd0908017dc61ec4bcba3
***special situtaion
when i change Discret:S2S to N2S, it can not running, 0 percentage.
>>> all situation have a result as NG, it has penetration although i have set self contact it
thanks
please take care, as your green part is a shell mesh, and not a solid one.
You are calling it self-contact, but what you're trying to do apparently is simply regular contact between 2 parts.
Instead of selecting all elements as master and slave, break into 2 different contactsurfs(set segments): One for the green part, and another for the brown part.
But first of all correct your model, so that both are 3d mesh.
When you create as 'set segment'/contactsurfs, you will be able to see these pyramids, and they should point each other, in order to the contact to be identified without any further MORIENT options.
0 -
thank you sir
