Hello everyone, i am doing linear static + modal analysis to be to AcuSolve for fsi simulation.
Optistruct simulation details: riser pinned at two end (constrain at xyz translation, free xyx rotation) + upward force (top tension) define as load. The loadsteps in optistruct are:
1. Linear static:
spc: defined
load: defined
2. modal Analysis:
spc: defined
method (struct): defined
statsub (preload): linear static
I get an error during importing op2 file into acuconsole-eigenmode manager; 'internal error: inconsistent number of eigenvalue.
The error only occur when there are two subcase (linear static + modal analysis). If i only do modal analysis without linear static, i can import the op2 file without any error.
Is there any way(s) i can exclude linear analysis in 'output: op2 card'?
Attached is the thread in AcuSolve forum with sim files.
Thanks in advance!
