i am trying to use the strain constraint for beam modal. when i do normal analysis i am getting both density and element stress 2D & 3D but when do topology optimization for same modal i am getting only Density results why i am not getting stress results . why i went wrong ?
stress Constraint
results
Hi Shabbik Shafiulla,
You should get 2 H3d files.
BR-,
Thomas
Hi Shabbik Shafiulla, You should get 2 H3d files. First one is *_des.h3d, this contains density results and will be used for reconstruction later. Second, is *_S1.h3d, this contains for both initial and last isteration the output you asked for. BR-, Thomas
Thank you Thomas Quenaon
