I'm simulating the Thermal of the brake disc and it's very slow is there any way to speed up this process
With this simulation I only want to find the maximum temperature that the disk can reach, I don't need the animation
You have set termination time to 1.1s, but the brake disc is stopped by around 4ms... if you only run to 5ms, it will be much faster, your timestep is around 2e-8s due to having some very small < 0.2mm elements and requesting 0 added mass. Attached allows 1% added mass and runs to 5ms only, run time is 1h 20m on my laptop
