As shown in the figure below, my map area is very small, but it is located at coordinates x=669899, y=3535813.
I'd like to set the bottom-left corner of the map as the origin, with coordinates x=0, y=0.
Thank you!
Hi, WallMan allows to select all objects via Objects > Select.Then all the objects can be shifted by a definable distance using Objects > Move selected object.
Hopefully this will help you further.
Best regards,Reiner
Hi, WallMan allows to select all objects via Objects > Select.Then all the objects can be shifted by a definable distance using Objects > Move selected object. Hopefully this will help you further. Best regards,Reiner
Hi reinerhI have another question and I hope to get your answer.
After I conduct a simulation, I obtain the following files as shown in the figure below.
They always come together with my map file (.odb). I want to keep only the .net file or organize these files into a separate folder.
If you have any suggestions or methods, please let me know. Thank you very much.
These are the 4 project files.Typically the result files are written in sub-folders for which the name can be defined in the GUI / project.
