what may be the reason for this error in optistruct?
I have updated the patch for new solver as well. still showing #192 error.
PFA.
Can you give a try by increasing default ram allowed the file to run. Also if possible share the .out and stat file of the run.
there was error in mesh file, I re-meshed the model, now it is running fine
thanks
