I understand that the coupled load option needs to be selected on the rotor, but there are always some problems. How do I set the parameters on the three images below?
To find the value of the data that you need to use, you can use the following formulas :
For example for the inertia : J=(1/2)*M*r² where M is the masse and r is the rayon.
For the friction : F=(torqur/Speed).
For the velocity and speed a t=0 you keep the initial value zero.
Best regards.
