Hi everybody.
I made some attempts on Acuconsole but I obtained wrong numerical results.
The steps I followed were as follow:
- Flow Model: STEADY STATE - THREE DIMENSIONAL - TURBOLENCE (spalart allmaras)
- Incompressible fluid
- thermophysical properties costant
Essentially, sarting from impeller angular velocity and inlet pressure, I'd like to obtain pressure and velocity distributions.
At first I defined the angular velocity in 'Reference Frame' (I assigned rotation center and angular velocity (about 2500 rpm)).
In Acuconsole I assigned the following values:
- As volume I assigned the fluid volume (material:Water, Body Force:None, Reference Frame: angular velocity.
- For the surfaces, after assigning 'simple BC type' for each surface, I assigned:
- Pressure (about 400000 N/m^2) for inlet; a value of eddy viscosity;
- No BC for outflow (I'd like to obtain the outlet pressure!);
- Angular Velocity for wall;
- No BC for wall_2.
Even if the anlysis converges (after several time steps), and even if the velocity distribution seems to be reasonable, the numerical results are completely wrong.
Since I couldn't find neither tutorials, nor videos, nor any other material, my last chance was to ask for your help. I also made the blower workshop with which I was able to understand some issues about Acuconsole.
At last I attach the .hm file and the .acs files.
I really hope you can help me. At least tell me if I'm completely wrong.
Please answer.
Best Regards
Stefano
