OptiStruct does not show any error and also does not show the result.I have observed that while processing number of nodes,elements and every other input (constraints,loads, etc) shows as zero.
Hi Shivam,
Could you share .fem or .out file of the run to take a quick look?
Hi Rahul,
Here are both the files attached which you have asked for.
I see your are using HyperWorks Student edition 2017.2 version.So HyperView window will be always greyed out (Analysis :OptiStruct).You can check the analysis info in run summary and results option will help take you directly to HyperView for postprocessing.
