Hi. I am preparing a simple 2D plane strain contact problem is Hypermesh for Optistruct. As you can see in the figure, the dark yellow bar is bonded two the blue, green and light yellow components and is fixed. The red bar applied with -Y displacement and it has frictional contact with the blue, green and light yellow components. For plane strain in PSHELL MID2=-1 is used, the CTPSTN and CQPSTN elements are used for tria3 and quad4 elements and also have assigned theta = 0 for CTPSTN and CQPSTN elements. But I am getting the following error for every elements. Please help me with it. I am also adding my model herewith.
This line was interpreted as:
7795:CTPSTN, 1002748, 12, 7312, 7298, 7326, 0.0
*** ERROR # 1000 *** in the input data:
Incorrect data in field # 7. Field 'G4' of CTPSTN bulk data.
Expected INT >= 0 or blank, found REAL (0).
Debarshi
