Hi.
I want to perform a topography optimization analysis for this part. Yellow is the non-design space and blue is the design space. The big rigid is SPC and small rigid is loaded. I want to have minimum displacement in X in around the middle hole. Everything is shell mesh with 5mm thickness. I am using a higher thickness as it is a solid body in reality.But I am getting this error.
Please help me out. Thanks in advance.
*** ERROR # 1812 ***
Multiple responses are assigned to the DESOBJ objective function.
A MINMAX/MAXMIN objective function definition with DOBJREF should
be used instead.
Number of responses = 181
This error occurs in module "dppdrv1".
