I'm practising a tutorial about ditching using SPH. I obtained the starter and engine files from the installation library. When I run them on Radioss solver, it worked perfectly fine. However, when I open the starter file in HyperWorks, export it as solver deck, then run it using Radioss solver, it generated errors. I thought that these methods of running the analysis are the same, please correct me if I am wrong. The model file I used is attached below.
Thank you!
Kai
