Hi all,
I'm trying to update my solver (RADIOSS) to version 2019.2. I copied the the executables into the Altair\2017\hwsolvers\radioss\bin\win64 folder. How do i use the correct version in my run manager? Many thanks for any help.
Cheers, Tim
Hi Tim,
Why haven't you used the installer for RADIOSS2019? It should create a new folder with your executables. Inside this folder there will also be a new Run Manager for version 2019.
When running a solver, you could specify the version by using the option:
-v 2019.2
But I'm not quite sure that only moving the executables would work. You can try.
I would recommend installing HyperWorks 2019.2 to get Radioss 2019.2. You might be able to copy the Radioss executables into a HW 2017 install then use -v 2019.2 as a run option but there is no guarantee that works. Better to install HW 2019.2.
Thanks,
Andy
