Start OptiStruct from Command Line → How to set RADFLEX_PATH env variable?
Willi Stork_21755
Willi Stork_21755 Altair Community Member
edited September 2021 in Community Q&A
Hello Altair Community,
I try to start OptiStruct through the following command:
Path\to\optistruct_2019_win64.exe Path\to\Solverdeck.fem -analysis
then I get the following error-message:
RADFLEX not found
 *** FATAL ERROR # 9174 ***
 *** Error starting Radflex licensing utility.
 *** Please check RADFLEX_PATH env variable.
 *** License checkout could not be initialized.
As I can read in the error-message there should be a RADFLEX_PATH env variable set.
This env variable doesn't exist on my stystem.
So my question is, how do I set this env variable correctly, so I can run OptiStruct from the commandline?
Additional Info:
  • OS:         Windows 10 Version 10.0.19042 Build 19042
  • HyperWorks: Version 2019
  • I wasn't able to follow the sollution provided here, as it's for a linux-system.
Best regards
Willi Stork
Edit: Mods in case this belongs into the OptiStruct-forum please move it there.
Best Answer
  • Adriano_Koga
    Adriano_Koga
    edited September 2021 Answer ✓
    hi,
    you should call optistruct.bat instead.
    D:/Program Files/Altair/2020.1/hwdesktop/../hwsolvers/scripts/optistruct.bat your_file.fem -youroptions...
  • Adriano_Koga
    Adriano_Koga
    hi,
  • Willi Stork_21755
    hi,
    thank you very much, now it works!
