Contact and convergence error
svez
Altair Community Member
Good morning,
I'm running a transient analysis of 2 gears (one of them with a preload and the other one with an imposed rotation). When I run it with Optistruct I get 2 problems:
- *** ERROR # 4965 ***
Maximum number of time increment cutbacks reached,
analysis aborted. - The biggest problem comes here, if I analysis the results, the contact status is 0 everytime. The gears rotate but they don't seem to have a good contact. Moreover, I get high normal contact forces at points where there should be any contact (see image attached).
I also attach the .fem to make it quicker and the .out from the previous simulation
Thanks!!
