I am trying to perform a modal analysis in Hypermesh for the ANSYS solver.
I want to tell ANSYS to use the Analysis Type "MODAL" , and I want to enter the number if eigenfrequencies and eigenmodes to output. I cannot find this anywhere. Where do I find it in Hypermesh? I also want to make sure that I get vonMises stress as an output for all nodes. All I have found up to this point is a tutorial for how to set up modal analysis in hypermesh for Optistruct, which was not applicable for ANSYS (https://www.slideshare.net/RahulShedage1/normal-modal-analysis-in-hypermesh-72162746 AND https://altairuniversity.com/wp-content/uploads/2017/09/modal_analysis_MG_sanjay.pdf ).
I am using Hypermesh version 2019.1.
I have a geometry with the correct boundary condition, everything has been meshed. I am just looking for how to set up the modal analysis, which is the last step I presume.
Kind Regards
Henry
