Difference between TEMP and TEMP_LOAD Subcase options
User: "mpvnaresh"
Altair Community Member
Updated by mpvnaresh
HI
I am running a Non Linear Quastatic analysis for an assembly  in which one of the components is heat assembled .
To Represent the pre thermal stresses i have given TREF  and A value in the MAT1 of the heat assembled component,and applied a temperature(TEMP card) for the same component .
For the remaining all bodies i have given A=0.and temperature is applied with TEMPD.
Now i want to know how can i combine TEMP and TEMPD to be  able applied for a subcase .
and i am confused between TEMP and TEMP_LOAD.
can any one please helpme in this.
1 - 2 of 21
    User: "mpvnaresh"
    OP
     I referred some NASTRAN Reference guides . now I got clarification . Thanks
    User: "Muhammet Gungor_22489"
    New Altair Community Member
    Updated by Muhammet Gungor_22489
    Hello mpvnaresh,
    I wonder if you could share the reference guides if it is possible. Or could you explain what is the difference.
    Best regards,
    Muhammet
