Hi alll
i am running a nonlinear analysis with frictional contacts .
i am getting an error as shown in the attached pic.
please help me in resolvivg this
Can you please share the .out file of the run?
Sir I sent it by secure file drop
Can you give a try by updating solvers to HW Solvers 2018.0.1.I see there is one fix available for internal programming error. PFA screenshot for same.
sir i updated it and put a run.
again its generating same error.
Could you try again by unchecking GPSTRESS/Stress: Corner stress /OLOAD defined in Global Output request.
sir
those are not activated in my model file
is it a software bug or is there any chance of model issue.(controla cards or contacts ).
I tried with stick and slide contacts also , but the result is same
Is it possible to share .fem file ?I could give a try on upcoming 2019 version.
i tried to solve the same problem in linear static solution with freez contact , the result is same
it solved for linear static solution with freez contact type , but giving all displacements and stresses Zero
I tried running by changing various nonlinear parameter in 2019 and found by unchecking param post -5, model runs through.
Could you try same for your model and update us.
thanks sir , the solution is running
But how it is connected with post parameter.
and when the solution is going on ,in the optimization summary i am getting some variable,grid/element id ,value what are they actually represent
Please update us the final outcome.Will report this to the development team.
sir can you please suggest which type of contact is best suitable for these kind of models
i am geting the results only by properly constraining the body for which moments are applied .
still the contact results not seems to be crrect.
is there any way i can check whether the contact is working properly.
as you said the solution is running with parm post -5 deactivated.
when ever there is post -5 in a nonlinear quastatic analysis its genetating no2km.F error .deactivating this allowing the solution to run.
Thanks for the support.
