Hi
I am simulating a permanent magnet motor under rotational stresses in which magnets are embeded.
As the magnets are tightly inserted ..can i moel it with FREEZ contact or which contact is most appropriate for this one .
If you want to ensure zero relative displacement between master and slave entity then Freeze or Tie contact is fine. You could run linear analysis with contact type freeze.
Thanks for the reply
