I am performing an analysis using gasket materials. However, I am encountering the following error:
*** ERROR # 4704 ***
The loading path must start from the origin.
MGASK #15 (BEHAV = 1).
*** Run terminated because of error(s) in the input data.
All the loading and unloading curves start with zero pressure and at zero clearance as shown the pics.
Unfortunately, I am not allowed to share the model. Could someone identify the cause of this problem?
Thanks in advance.
