I am trying to run an optimization in HPC. The optimization is converging but the calculation is ending with a system error - Signal 11 :: SIGTERM. I am attaching the output files here. Unfortunately I am not allowed to share the input/model file. Any observations or suggestions in order to overcome this error is highly appreciated.
Do you get results files?
I got result files that I had requested in H3D. However, .oss file was not written and in the result folder a lot of scratch files are still present, which i suppose is due to the premature termination of the simulation.
<?xml version="1.0" encoding="UTF-8"?><?xml version="1.0" encoding="UTF-8"?>
