I am modelling heat transfer, (natural and forced convection) of a cabinet with an internal heat source. Please see attached figure.
I am using the Boussinesq approximation and including gravity so need to use 'Hydrostatic pressure on' setting.
Can someone please explain where to set the hydrostatic pressure origin?
Am I right to assume it is in the middle of my outflow surface that is venting to atmosphere?
Thanks in advance.![]()
