I'm doing a simple compression test of this stent model as shown in the attachment.
As it is cylindrically pressed, so I built a new cylindrical system. And I set up IMPDIS. However by MODELCHECKER it showed 'negative or zero volment of solids'.
I'm wondering if the parameters of the card PSOLID correct or not?
Or due to the meshing problem?
Any other reasons might cause this error?
Regards
Chen
this modelchecker error indicates badly shaped 3D element (meshing issue). The solid is decomposed into sub-volumes associated to each integration point. If the element is badly warped, one sub-volume could be negative.
Check your element quality.
Tool > check elems > 3D > aspect, jacobian, warpage, tet collapse
