If I've already calculated sin(theta) and cos(theta), for a three phase to D-Q transformation on a TI chip, is it more efficient to use the PSIM abc-dq0 block, or the TI DMC Clarke in line with the TI DMC Park block?
The PSIM abc-d0 blocks were developed before TI developed the DMC library.
We have not compared the code efficiency between those blocks.
I have attached a simple circuit schematic. You may compare between the codes generated from those blocks.
