To check if for eg a RBE2 is connected to a mesh, or update that connection after importing a new mesh Hypermesh has the Equivalence tool; what about for SPCs? Is there an 'equivalent' tool to check a SPC is connected to a RBE2
Thanks
You can use the find panel to find elements attached to loads.Tool->findThen find attached elems attached to loads.
because SPCs are created on Nodes, you cannot use equivalence tool to check or equivalence them to mesh
so if you need to check, just follow above guide of @Nick Zagorski
if you need to equivalence SPCs to new mesh, just create temporary elements on the SPCs (example: mass elements)
then you can select those elements to equivalence to new mesh. Delete temporary elems finally (should create them in a private ^component, and delete that comp)
