I did a Civil Engineering course some years ago and this is a question from my textbook that I haven't been able to solve.
A flat plate 1m wide and 4m long moves with a velocity of 4m/s parallel to its longer sides through still air of kinematic viscosity 1.5 * 10^-5 m^2/s and density 1.21 kg/m^3. On one side of the plate an initially laminar boundary layer is formed. On the other side the leading edge is roughened and the boundary layer may be considered to be entirely turbulent. Assuming a critical Reynolds number of 5 * 10^5 determine the ratio of drag forces on the two sides.
For laminar flow CD = 1.46/ (Rex)^1/2 and for turbulent flow CD = 0.074/ (Rex)^1/5
How do you work out Rex ?
and where does critical Reynolds number come into it ?
I really would like to get an understanding on this,
If someone knows about this, it will be much appreciated that you could please reply to.
Also On one side of the plate it says that an initially laminar boundary layer is formed'.
Does this mean that this side of the plate has laminar and turbulent flow ?
