Good day, all.
I created a geometry in Spaceclaim in mm, but when I tried to import the same geometry in EDEM, it appeared so small and not according to unit (mm). So much so that when I tried to create a particle factory using the cylinder option in EDEM, it appeared to be bigger than the geometry.
I have attached a picture; the geometry is in red.
I would appreciate it if anyone could help out with this.
Thanks.
