I have a created a derived load case - Envelope with 7 subcases from 7 odb files. Totally there are 21 subcases, but I have selected only 7 out of them.
I have exported the config file which has the subcase id as in the Hyperview. (3,6,9,12,15,18 & 21)
But, when I save the session file, the *appendsimulation statement in the session file has different subcase ids ( 3,6,9,13,14,17 & 20) which are mismatch to the Hyperview and config file. Is it normal and any reason for this??
Pictures in attachment
Subhu
Session file writes the subcase index as a zero indexed vector.
Can you verify the subcases themselves are correct (not the matching IDs)
