hello support.
I am trying to do part meshing.
This is a part with holes, but the mesh created without washer mesh around the hole.
on earlier versions (Hypermesh 2019) I used to do midsurface -> auto cleanup, define the parameters for the washer and then mesh the midsurface.
In the Hyperworks 2021 I tried Mesh -> Param -> define the parameters and -> midmesh -> automatic.
It seem that it dose not matter what parameters I use, all meshes looks the same, and without washers mesh.
please advice.
Best regards,
Edan L.
