When I create a SolidMap for one of my Solids it states in the left bottom corner:
'Waring: dest has 2 unmatche fixed points. Node associations my be wrong.'
And the outcome is this:
How can I fix this?
Thank you.
you can try using the 3D>>line drag
create a shell mesh in your source and drag them though theline.
or if it is a circular shape, use the 'spin' panel.
Hi, Thanks for the quick response.
This is just a cut out and actually there are kind of 'arms' attached to this solid, whose mesh has to be considered.
Line Drag or Spin would just create the mesh I believe. Thats why I am trying to fix this instead of creating a simple new mesh.
Thanks.
Share your model?
